Just an update on my issues with thermal limiting on my BBSHD:
So after a longer ride, I've discovered that not only is the Controller temp sensor far too restrictive, but the motor-only 'Temperature Sensor' option is also too limiting.
(the 'All' setting I tried at first kicked in almost immediately and made the bike almost unrideable - concluded this was because the Controller hit the limit very quickly, as when I changed it to 'Motor' I could ride for longer - but it turns out not long enough!)
When my display (860C) is reading 160-165 under 'Range' and the temp limiting is restricting power to 5-10 amps, the motor casing is only very warm to the touch - i.e. I can put my hand on it for extended periods without a problem. I've had my BBSHD much hotter than this many many times over 1,000+ miles with no issue. Perhaps I've been running it too hot before? But that seems unlikely as I am limited to 30A (no shunt mod) and others are running 45-50A or more..
Is anyone else having this issue? It seems to me that the 75C threshold used in the thermal limiting logic is much too low - not only for the Controller temp (should max out at 100C?) but also for the motor temp (probably should max at 90-100C as well).
If not, then there must be something wrong with my motor or my temp sensors! But I can ride at 30A continuous up long hills just fine (as long as I've set the 'Temperature Sensor:' option to 'Disabled'!). Would love to figure this out as I don't like riding with all the thermal protections disabled, not that the stock firmware made use of this (did it?). Thanks!
