Somehow I missed this build adventure entirely...sorry about that.
I've had SLA fall off of CrazyBike2 during a couple of experiments, and was lucky that neither was damaged, but on older experiments with DayGlo Avenger, I did drop one on concrete and it cracked the outer casing. Still worked for a long while, but it was doomed.
BTW, as far as "most frugal person you ever met" goes...I'll dispute that and nominate myself.
But my builds will never look as nice as yours.
Oh, regarding the turn signals and such, here in Phoenix I not only haven't had any issues with that, but have actually been thanked by the police for having the "proper" lighting.
I just still assume I'm invisible regardless, but at least having the same visual language as everyone else on the road for communicating traffic intentions to all around me (including pedestrians) helps immensely. So few people (including police and other cyclists!) seem to know what hand-signals are anymore, but everyone knows what turn signals and brake lights mean, even if they themselves don't use them.
It's possible one of the terminals is broken inside the battery, cracked at the post/plate connection. It might've begun arcing during the stuttering period, and burned away whatever little connection was left, making it suddenly 0V. That might actually be fixable, if you were willing to cut into the casing of the battery to find the spot (probably at the corner where the terminal is; it might even be obvious which one if there is any damage or cracking nearby).Ornery said:Do you think that battery died because of too much discharge? It was only three months old. I think the bouncing hurt it. It just quit suddenly, no fade out.
It might work; there is another tensioner method that's similar, called a ghost sprocket, used on some tandems and the like. It uses a single large chainring in between the two directions of chain, inside the loop.I was kicking around the idea of an idler with a friend. He was wondering if a duel set of sprockets pinching from above and below, just floating on the chain, would work? I'll see if I can make a sketch...
