megacycle
8) thanks
wb9k said:I'm told there have been some studies recently done that show that at 1C or less, no compression is needed. However, cells have to be constrained somehow just to be usable, so some level of de facto compression will almost always be present.
IamIan said:wb9k said:I'm told there have been some studies recently done that show that at 1C or less, no compression is needed. However, cells have to be constrained somehow just to be usable, so some level of de facto compression will almost always be present.
A study I found a bit ago that kind of goes into some of the technical side of the gas formation itself.
Link
ejonesss said:can someone post a copy that does not require payment and registration?
Link
h0tr0d said:Have you seen this?
http://www.rimac-automobili.com/upload/tbl_clanci/battery_pack_3_165528.jpg
http://www.rimac-automobili.com/upload/tbl_clanci/battery_pack_4_165533.jpg
powersupply said:Spring loaded, very Interesting.
So how are the tabs connected then?
Is there a (cooling?) fluid flowing through?
Thanks!
... and weigh less.bigmoose said:Rimac uses recognizable springs, A123 uses thin stainless bands. To me they are both "springs." The bands are cheaper and package better.
CaptainKlapton said:Looked through this thread and didn't see this document yet:
I just found it a few weeks back, there is information on mechanical support starting on pg.32
From what I have read, there is ~1% expansion through a discharge cycle. As the cell ages, the nominal cell thickness can grow by 3-5%. For A123 cells the ideal pressure is between 4 and 18psi with the ideal pressure being ~12psi. Maintaining 12psi can increase the life by 500 cycles over that of 4 or 18psi.
CaptainKlapton said:I didn't expect it either![]()
https://www.buya123products.com/
They have a couple of them.
But more often than not, if you know the name of a document you can search it directly on google and bypass many of the pay walls and other blocks by clicking on the PDF button next to the link.
