andreym
Shorter version of video as promised
[youtube]_bhBK0RX2Vs[/youtube]
voicecoils said:Did you make any spare torque arms sets made to sell or have drawings?
My D8 with broken hanger could use such a neat design!
andreym said:voicecoils said:Did you make any spare torque arms sets made to sell or have drawings?
included in attachments. Please make sure you corrected the hole for the hanger
I know about needle bearings, but they will arrive not earlier than in a month and I wanted to ride tomorrow! So they will waitfull-throttle said:Nice damper! Did it fit faith out any issues? I'm going to do the same with mine. Looks like the mudguard will have to go.
The lower shock mount rotates quite a bit. Perhaps a needle bearing mount is better.
mine rc4 was bought from the guy with demo8 and it has 15mm bottom hole instead of standard 12.7mmfull-throttle said:PS the reducers are same size on your old shock (Fox Vanilla RC) and the new one (Fox Van RC4) Why did you had to change yours? Were they worn out or something?
Rear wheel was in the air most of the braking :lol:GCinDC said:nice brakes! better safe than sorry. was the back tire skidding out? EDIT: duh, i just remembered you don't have a rear brake!
with the batts up front, would it endo easier?
It IS working as a high beam, but most drivers does not see it more than couple of seconds, so no problem at all.Allex said:Feels like you blind all the cars, or is it just video?
Maybe you should lower your LED a bit?
about a week agoGCinDC said:when did you get hero3?
is the sound much improved?
max regen amps 40a battery current, usually 15-25 battery amps on 75volts,also i meant to ask before, what's your max regen A?
yes - thermosensor is there - max temp was about 190Cyou have a temp monitor? what's the max temp C it's reached?
Gopro is fine, but i already ordered another case for itGCinDC said:i really hope the lens of the gopro is fine. but whatever, they're replaceable!
did it die in your pack? you just replace w/ new?
sure I willGCinDC said:maybe next time you can do a capacity test after it's been charged to 4.49V.
