larsb
Hi,
This thread is making it possible for me to try a motor build - big thanks!
I am thinking of copying straight off but use a single speed hub, gives me 80 mm of motor width to play with instead of around 50.
I have only a basic understanding of the mechanisms involved so i have a few questions:
If scaling to get max number of plates i might get 4 or 5 stators in 80mm width. Volts needed are proportional to stators so then need to run 80*(4/3) V controller for four stators, correct?
Building a controller is outside of my limits, what kind of controller is good with a 4 stator setup of this motor?
I have a CNC milling machine that i built as a diy project so i can mill any plates or holes needed.
If using other shape of coils and magnets then what would be your recommendation?
I am also considering increasing diameter to get added torque but then i think the pole/coil setup need to be changed and that would create an additional 1000+ questions.
Lebowski: If you have thought of a optimized design that you don't have the energy at this time to do i'll be happy to do the building in your place
