I have the modbus communication protocol from ASI and the XML file, Though the XML file is hardly an a clearly readable format, like a command reference table in an instruction manual. You said you have been doing a bunch of work on this, what I'm curious of, is:
(1): Have you successfully achieved this (motor throttle control via modbus) using your own hardware/software?
(2): Can you control the motor from the PC in the BACdoor software (eg, write to the register and make the motor spin at a constant speed)?
I ask because I do not have a controller yet, and don't want to buy one unless it will work.
In the BACdoor software there are the two following write windows with throttle settings, if you enter a value and click write will the motor start spinning?
Under "peripheral configuration" and "throttle"
Under "controller debug"
As far as the XML file goes, here are some of the relevant parameters that I have found, Have you played with any of them?
on line 2375:
</ParameterDescription>
<ParameterDescription FaultIndicator="false">
<BitField />
<AccessLevel>0</AccessLevel>
<Address>208</Address>
<Read>true</Read>
<Write>true</Write>
<Name>Control command source</Name>
<Scale>enum</Scale>
<Description>0 is serial stream / 1 is throttle / 2 is pedal sensor / 3 is throttle AND pedal sensor / 4 is throttle OR pedal sensor /5 is torque sensor</Description>
On line 2828:
<BitField />
<Address>247</Address>
<Read>true</Read>
<Write>true</Write>
<Name>Throttle sensor source</Name>
<Scale>enum</Scale>
<Description>0= Throttle Voltage, 1=brake1, 2=brake2, 3=CAN torque, 4=LIN, 5=Network Voltage, 6=10V bms in</Description>
On line 3176:
<BitField />
<Address>270</Address>
<Read>true</Read>
<Write>false</Write>
<Name>throttle voltage</Name>
<Scale>4096</Scale>
<Units>Volts</Units>
<Description>Filtered throttle voltage</Description>
On line 3916:
<BitField />
<Address>325</Address>
<Read>true</Read>
<Name>throttle setpoint</Name>
<Scale>4096</Scale>
<Units>pu</Units>
<Description>Filtered throttle signal</Description>
On line 5802:
<BitField />
<Address>495</Address>
<Read>true</Read>
<Write>true</Write>
<Name>Remote Throttle Voltage</Name>
<Scale>4096</Scale>
<Description>Networked throttle voltage</Description>
