I had to re-lace my mac 10t into a 26" Alex rim recently (see bike in sig) and these are the numbers I used in the ebikes.ca SpokeCalc.
It's all going to depend on your new wheel's ERD. (effective rim diameter)
For my Alex 26" rims it was:
Effective Rim Diameter 544mm <-- your rim's ERD, depends, check your rim documentation.
Hub Flange Diameter 172mm
Flange Spacing 54mm
Diameter of a spoke hole 2.3mm
Cross pattern 1
Number of spokes 36
Calculated Spoke Length: 194.2 mm.
You will have to order two different sized spokes because rear wheels are typically dished to account for gear cluster. Also depends on your frame, sometimes the right chainstay is offset so no dishing is required (unlikely.)
The gear side / drive side spokes happen to be 2mm shorter than these calculations, so 194mm and 192mm are the spokes for my rim @ 544mm.
Some people prefer not to dish their wheels and do okay as well, but you may have a problem with your tire rubbing the left chainstay depending on how thick it is.
As for which spokes to use, I highly recommend the Sapim single butted spokes. These spokes are 13 gauge at the elbow, the exact size of the mac flange holes (2.3mm), and taper down to standard 14 gauge after a few inches.
They will fit into standard nipples, use standard spoke wrench, and you can tension them properly.
There are lots of threads out there on how to build wheels and confusing spoke placement diagrams, videos etc... it looks scary but e-bike wheels are easy; they are the cross 1 pattern.
You'll have to learn to lace a wheel eventually if you play with bikes long enough.
Here's a good article:
http://www.electricbike.com/lace-hub-motor/
