Idontwanttopedal said:
Can't wait to see video of this running. Nice workaday always on your builds
Cant wait to shoot it right now i'm up shit creek without any solder speeeeewin' ran out round lunch time have half the wiring finished all wires sleeved with black cable sleeving looks schmick...I have a
pre-charge resistor setup on my main switch also another first on one of my e-bikes i
have used a FUSE on the battery wiring!! -->
Apologies for the blury picz :-(
I used liquid tape to cover the exposed metalz..Lovz electric tape
^^250amp fuse, if it blows while riding i will have more issues than the fuse i know, but
if i need to i have made a solid wire i can connect to switch/battery
to get home...
Farfle, or anyone that knows
...i assembled a shunt i for the CA when using the HV160
as per Justin's instructions at the time it has the wiring as per you instructed Farfle, i think...
just wanted to run it by to make sure i have it correct, two black wires i.e negative power, and current measuring leads B- and shunt - / S- I am unsure where i hook these on the CA
lead, obvious ..i think? one (B-) goes to the black wire on the CA? but what about the (-/S)
the second black wire, where do i hook this on the CA lead? I have the rest right...i think?
I run a red wire on the positive power battery wire then a white wire on the negative wire
controller side
on the shunt and a blue wire on the battery side
on the shunt
then connect these to same coloured wires on CA lead...correct?
Soz for the noobness...i checked the diagrams on ebikes CA and it confused me a lil more
:-| I should know this shit, pissess me i'm so dense with electric stuff aaaagh...
While i have everyones attention lol...by that i mean Farfle LOL ... buddy, you mentioned in PM
the throttle overide connections i.e the green wire. I run this too the signal wire on the throttle
while checking the ebikes.ca website i spotted a diagram explaining the connection
However, it shows a diode in the mix along with a current limiting resistor in the 3-5k
My question, what size diode do i use?
Cheers in advance guys, still kicking myself i ran out of solder tellz ya... Can pick
some up first thing, hoooopefully i can get some forward motion come tomorrow
arvo, i only have tomorrow before i head north to do some roo shooting on my girlfriends
fathers farm sooo, pull the ol finger out and get a carry on i shall!
KiM
