krlenjuska
- Joined
- Feb 18, 2019
- Messages
- 94
Riba - can i use 1N4004 diode instead of 1N4001? Only difference is voltage if im not wrong.
Looks like the old PIC K150 Programmer will also work.riba2233 said:It's simple once you have a programmer like pickit 2 or 3 with their own software, just connect it to pc, load the hex file, and press programkrlenjuska said:Most difficult thing to do for me is to program pic controller - never tried this
stevecahill said:Can anyone explain what specific mosfet leads the TVS gets attached to Gate, Drain, Source? In response to this: "Another TVS diode goes across the FET legs to catch what the other diode misses".
Thank you
Steve
palmer_md said:Has anyone decided to build a batch of these for sale. I'd really like to use this welder but do not want to go to the trouble of fabricating one. Or is there a recommended alternative for someone who just wants to purchase a welder similar to the JP spot welder?
Konaboy76 said:I can’t seem to find the pink/purple 100u capacitor on digikey. Can someone post a digikey link please. I think I found everything else.
wakko said:Riba - The souce code is missing the routines for obtaining the reading from the ADC. The mcppi file is also missing all the source code so you can't get it from there. Could you upload the code?
wakko said:Riba - Apologies, I've found that the function Get_ADC_Sample is included in the mikroC PRO libraries. I'm new to using mikroC PRO so I didn't know they had these libraries. I find that when you open the .mcppi file in mikro C PRO it refers to a source document called sw_pot.c but reports it as missing. I'm guessing the mcppi file is just a project file whilst the actual source code is saved separately as .c files. However you can simply rename Code.txt to sw_pot.c and it'll load up correctly.
Yes. If you have a pacemaker, don't let the welding cables get close to your chest. I think you'd have to be pretty close to actually cause a problem. More than a foot away should be OK.tomjasz said:Kweld mentions their welder can create issues with a pacemaker.
"This system produces significant magnet fields, do not use it when you have a cardiac pacemaker!"
Is this a concern with the JPWelder?
