The 1 A rating doesn't mean it will try to push through 1 A no matter what. :wink: It just means it will supply 12 V at whatever current the circuit draws, up to the 1 A limit, at which point it will either limit current, or shut down, or melt, depending on how sophisticated it is.ohzee said:Any ideas if a 12v 1 amp wallwart would be to much to power the unit ?
Figured id check before I use another to swap plugs. Thanks
riba2233 said:How do you even know that he used large conductors for parallel?
ohzee said:Test welds look good. Did have to dial it in some , but once I found the sweet spot they were consistent.
So ordering nickel from the suggested vendors one from ebay is about pinkey nail width and the one from electric rider is 5 times as wide.
Now that I have my own welder even if I had to replace a battery in a string it should not be so bad. I also plan on doing an obscene
amount in parallel and only use 4.12 to 3.8 of the pack majority of the time. Of the 400 tesla cells I want to get as many I can into
my frame.
my frame.
If you have time, a photo of your welder with the battery you are using to drive it and a macro shot of a weld would be nice as well...ohzee said:Test welds look good. Did have to dial it in some , but once I found the sweet spot they were consistent.
