Farfle
Miles said:
If I had room for bigger fins, I'd rather use the space for a bigger motor
Very true... still hate to see it with weenie little fins though
If I made them narrower, they might look taller?Farfle said:Very true... still hate to see it with weenie little fins though
Miles said:If I made them narrower, they might look taller?Farfle said:Very true... still hate to see it with weenie little fins though
Miles said:I'll look into optimising them before I finish. At the moment they're just a placeholder.
Does it have a ring bearing?zappy said:........regarding air gap, Just for an example I have an 80 series turnigy out-runner motor, and with feeler gauges the air gap measures .9mm. The can is also very thin with a fair bit of magnetism on the outside of the can (enough to make a screw stick vertically out off the can by its head). If i made a can with a 1mm smaller inside diameter, closing the air gap to .4mm what benefits could be expected ?? and what benefits from upping the thickness of the flux ring?.....
8) It's great to have someone with expertise in composites! Thanks for the offer!zappy said:With winding the kevlar, everything said is correct. I have a lot of filament winding composite experience. I used do do R&D for these guy's
http://www.cstcomposites.com/
The kevlar thread/filament is very waxy so is hard to bond well so epoxy with a higher enough glass transitional temp for max expected magnet temp will be needed and may be hard to find in the tiny amounts needed. I have a patch of kevlar off cut if you need a few threads for a couple of motors or some 24k carbon filament i can send you for free if you want. These fibers are very strong and you could tease out the filament to be very very thin (for min air gap interference) and it would make it bomb proof especially at such low rpm.
Zappy
mdd0127 said:Your motor looks beautiful Miles!
While the electrical/magnetic stuff is over my head, I do have one tiny suggestion. Would it be possible to make the cooling fins form a spiral? If so, a thin can could be slid over the motor, sealed at the ends and make for a very low profile liquid cooling option.
I'll be shopping for a motor for my next build soon and the one you're working looks perfect.
