Sorry to dig up such an old thread
My MAC has developed a fault where it just won't run properly anymore.
Trying to run the motor as a whole wheel just produces a kind of whining sound. It looks like it's trying to go but cuts out completely after about 3 seconds.
I've taken the motor unit out of the wheel and removed the sprag gear assembly.
Holding the axle firm and slowly twisting the throttle, it spins for up to 3 seconds, then stops.
Only releasing the throttle and twisting again brings it back to life, but still only for a max of about 3 seconds.
I tried using Knuckles hall testing procedure with a multi-meter and got the following:
Negative and blue showed nothing, even whilst turning the wheel as in the video
Negative and green showed just over 5 volts and didn't change whilst turning wheel by hand
Negative and yellow showed just over 5 volts and didn't change whilst turning wheel by hand
Would this test still work for a geared motor and does it look like at least one hall sensor is defective?
