momosfet
Hi, long time reader first time poster here.
I have a quick question regarding MT/MR series of connectors (originally Amass).
In short: why are XT60, MT60 etc. very common while XT30, MT30 etc. are not. 30 series should 'in theory' suffice for most low power e-bikes / e-scooters?
Longer explanation:
I am currently replacing dead 250W controller for a new 350W one in a 36V ebike. Since power-wise it is small upgrade and ebike was quite nicely made I try to keep as much of original parts and wiring as I can. I am using cheap Aliexpress controller, so not much data is available, even less reliable. Label claims 24V/36V input, max. output 17+/- A. Now, usually I would solder XT60 for battery connection and MT60 for motor, but I can't quite fit the bulky MT60 in existing case. I have much smaller MT30 laying around, so I figured I would check its specs. Turns out that it should carry 15A continuously, and up to 30A peak, which should be more then enough for 350W controller. The AGW16 wires that are soldered onto the controller also fit this picture. But, outside of drone makers I did not see anyone use this line of connector neither for battery nor for phase connections. So I wonder, am I missing something?
All help would be welcomed!
Longer explanation:
