Once again, these are all applicable techniques for wiring 30A and lower stuff for e-things. Once this threshold is passed, one needs to use better methods; the proper crimping apparatus along with rated barrels and terminals.
DO NOT expect good results using an automotive fuse over about 100V because if it blows, it will do so with a plasmatic flash. (flame on, flash!)
(good names for a band)
...of course it's the AMP rating of the fuse that counts, the voltage rating is where the fuse is expected to not be so destructive when it goes -poof-
I'd be more inclined to apply a ceramic/sand fuse over 100V because I like a 10X safety factor in anything I personally build (which is one of the reasons I build things).
But I run my e-stuff with lower volts and amps than the otherwise unlicensed motorcycle builds found elsewhere on this board and feel perfectly safe using these assembly methods.
-Methods accumulated over a lifetime of first doing it wrong, modified until getting it right.
I decided the fuse holders I'd previously used put to much stress on the cabling so I substituted a more direct method. Crimping 0.250" QC terminals directly on the wire ends.
My camera battery decided to die so only so much is documented.
note- I really like lithium camera batteries, since they last for about 600 photos with the Canon and 400 photos with the Nikon (as opposed to a dozen or so photos with alkaline batteries with an Easyshot Kodak that wouldn't even turn on with various brands of NiMH)
