John in CR
100 TW
AJ, Mr. I have 10 fans in my computer, but I don't use air cooling, it's quite simple. Doc doesn't hassle and mock others, so others don't hassle and mock him.
John in CR said:Hey Doc,
Since you already have your windings split in half, what about putting a controller on each one? Wouldn't 2 18fet controllers be better than 1 36fet?
Ypedal said:And AJ.. Doc and Methods ..LFP.. and a few more don't qualify to be among us " normal " power hungry bastards.. they are in a class of their own lol..
liveforphysics said:John in CR said:Hey Doc,
I think you're on to something here John. As I've been learning (the hard way), current handling does not scale-up well. On paper, if 1 fet is good for 50, 2 fets is good for 100, 3 fets is good for 150 etc. In practice, the distance in the legs and board traces between them, along with various other factors makes for a plague of paralleling switching issues and unbalanced inductive path issues etc etc. Better to have more groups of FETs each switching less current, rather than having 1 larger single group switching all the current. It would be a pain to run 6 wires out of the hub, but I think it may be the best solution for milking every last bit of power potential from off the shelf controllers.
liveforphysics said:Bigger FET packages in smaller numbers is the key to building a reliable monster controller IMHO.
Doctorbass said:liveforphysics said:Bigger FET packages in smaller numbers is the key to building a reliable monster controller IMHO.
Yes! for sure.. it's interesting.. but :| .. does they exist at the same price of a 36 fets controller?
I need IGBT!!. lol...
following this.. i bet i'll melt that X5 before the end of 2010!
Doc
John in CR said:Doc,
Something Fechter suggested for my low turn count motors is to put some inductance on the phase wires to help protect the controller. Do you have any ideas for cheap toroidal cores that will work with our 10ga phase wires?
Mark_A_W said:Doc
My 18 FET Infineon "Crystalyte" controller also draws double the current that you program with the PC.
But my 18 FET Infineon "soft start" controller was accurate.
I don't know why.
And umm...I think your controller is dead now
Good to see the DH frame is working out for you, I love mine, it's rock solid.
Mark
Doctorbass said:Mark_A_W said:Doc
I don't know why.
Mark
Now 3 of us can now CONFIRM that the real measured max current and the max current programmmed of the instant start 18 fets controller is twice the supposed value??? ( without modifying the original shunt)
Seriousknot said:Hey Doc,
How's the prognosis for the controller? Do you think she can be resurrected? Here's something you might find interesting....
http://jnaudin.free.fr/steorn/indexen.htm#EMF a way to cancel Back EMF!!
