bsterne said:I have a new Ping 36V 20Ah V2.5 battery with Signalab BMS, but I think something is broken. I have already replaced the BMS once. After charging, the voltage reading coming *into* the BMS is 42V, but *out* of the BMS (i.e. my discharge leads) measure only 32V. How can the BMS downgrade the voltage? When I check each cell group (via the sense wires coming into the BMS), they are all 3.8V except for one which is 3.5V. Is the presence of this 3.5V group causing the BMS to cut out somehow and only send 32V?
Any help is appreciated!
- Brendan
If one led is not on, it doesn't matter. If all the 16 led are on, the pack should be fully balanced. But if all the leds are not on, it doesn't mean the cells are not balanced.
The leds are originally designed for troubleshooting. It's for detecting selfdischarge by deffective BMS.
dnmun said:did you measure the voltage on that shunt? is it the same as the other shunts where the led is lit?
if you had a single cell charger with some alligator clips, you could charge up the one and see if the led turns on then.
StevenR said:I overheated it on a ride and had some solder melt such that when I hooked up the charger, I think I let the smoke out of the charging MOSFET. They have what looks to be TI BN7X51 in all positions (charge and discharge).I had th same problem few hour ago with my V2.5 48V 15Ah Ping battery.
The BMS have 5 mofet soldered close together on the board.
The shrink melted right above the two last mosfet.
Now when i connect the charger these mosfet become very hot.
The rest of the mosfet for discharge work ok.
I join 3 pics:
i'll contact Ping to get a replacement BMS. After all.. I've bought 7 of these battery!
Doc
