sn0wchyld
im struggling to think of a clutch dump behavior that couldn't be matched by a more dynamic throttle response (And possibly just some extra phase current) - think about whats going on - a clutch dump is using the flywheel momentum coupled with the relatively fast action of dumping a clutch to provide a very fast, very high spike in power output (and a resultant high spike in torque/thrust).
Perhaps whats needed (for EV trials) is not so much a clutch, but a switch (possibly attached to a normal clutch leaver) that enables a higher throttle ramp. Theres no doubt a controller can dump large phase currents into a motor to produce large spikes in torque (think controllers like the old infinion units that dumped full battery current into the motor for a breif moment on startup) so its not a question of capability as much as a question of response times. It takes much longer to twist a throttle from 0-100% than it is to release a clutch (given dumping a clutch effectively achieves the same thing, ie going from 0-100% throttle in a heartbeat).
A simple solution may be to just have a clutch like leaver that reduces the max throttle from 100% to 0% as its applied, enabling the rider to apply the throttle to 100% without any power actually being applied, and then release the 'clutch', thereby going from 0-100% throttle much quicker than they could by twisting a throttle alone. Couple this with an appropriately programmed and beefy controller and a motor that wont saturate too early and you have your clutch dump effect, no actual clutch required.
tldr: seems to be more of a programming/setup issue than an actual lack of a clutch.
