Hi!
I got edge 3000W sineWave controller from LA-EBIKE with the EDGE motor. see link:
https://laebike.com/collections/controllers/products/edge-stage-one-controller
Also I got the CA v3 connected directly to the controller.
When the throttle is connected to the CA the motor won't run at all.
I think I need to configure the CA.
I also need to configure the current shunt resistance so the amp measurements will be correct.
Is Anybody got some experience with this controller and willing to share it? that would be appreciated
The motor runs when the throttle connected directly to the controller and I get max speed of 43kph (23 MPH) on flat road.
I'm using 60 volts battery (67 max). so I think the speed is a bit low for this configuration... is there any way I can increase the speed?
Thanks in advanced!
Thanks in advanced!
