theotherkid
I built a 60V 36A dirt bike for my son out of an old Razor MX500. I got the power throttle override working great, however I'm still getting limited on power according to my CA diag screen. The A and W both flag even if I raise the power limits up way above. The only factor I haven't addressed that I can think of is I'm using a much larger shunt than necessary because it came with my used CA and I didn't realize it would keep me from changing the Calibration setting from High (kW) to Low (W) because you can't set a 0.25mΩ shunt when it's set to Low (W).
Parts:
Motor - BM1109 style 48-72v 3000W BLDC motor
Controller - Generic 60V 36A controller (18 mosfets I think)
Battery 60V 20AH w/ 40A BMS
CA HC V3.0 (bought used with no sensors, just a shunt)
Speedometer, Temp, PAS, Torque, AUX POT, are all disabled. Basically just have the throttle wire plugged in to the CA and THrO out to the controller. Ground and +5 are still connected directly from throttle to controller (does that affect anything?)
Throttle mode set to Power. (same results when set to Current)
Max power set between 1500w and 3000W doesn't seem to make a difference beside making the throttle go full speed before a full twist.
Max amps set between 26A and 46A does same thing.
Still a little unsure about how these affect things. I can't finely tune them as good as advised because of my Calibration setting is stuck on High (kW)
A-Gain - 999
W-Gain - 550
I'm only pulling about 26A and up to 1.8kW max or take when looking at the screen. I thought maybe my THROTTLE OUT Up Rate was keeping it from using full power during acceleration, but that doesn't fix it and it still maxes out around there going uphill with heavy load on.
Other unique details:
The controller has a 3-speed switch that is hard wired to speed 3 right now (It has a loop plug hanging to do this when no switch is connected to stay on highest speed) and a seperate "speed limiter" wire that i hooked to a switch. It seems to work to drop the speed whilst keeping the throttle action the same.
I'm realizing as I type this up I need to retry changing the throttle to Pass-Thru and see if it still limits the speed. I think I tried that first before I started adjusting calibration on the CA, but I have done so many things one at a time i'm starting to forget if I tried that after i got the throttle calibrated correctly. Either way, the A and W are flagging when it's reaching max speed so it has to be something in the CA (unless i'm just a moron).
![PXL_20231016_224530772.jpg PXL_20231016_224530772.jpg](https://endless-sphere.com/sphere/data/attachments/203/203120-7620bf782304c4728047ef4f13762122.jpg)
Parts:
A-Gain - 999
W-Gain - 550
