Hi, can someone help me?
Recently got a ebike with a chinese charger, the charger worked for the first 4 times then blew up on me.
Ordered a Satiator and made a custom profile for the battery, the battery is down to at least 10% but when plug in to charge with the custom profile the Satiator says charge complete after 2 seconds.
In the Satiator manual it says the charger will not attempt to charge the pack below the trickle start voltage which I set to 5.9v, thats the minimum you can set it to on the Satiator.
The battery is a 60v 18ah.
So I don't know if the Satiator is not compatible with the battery or I have not set up the profile correct or the battery cell is too low or its something else.
