RC throttle interface build tutorial........
recumpence   100 GW
Location: On Earth right now. That can change at any time, though..........
Re: RC throttle interface build tutorial........
Post by recumpence » Dec 12 2010 7:47am
Swapping two motor leads is the proper way to fix it. Motors do not have wires that are polarized (wire color) a certain way. I just ignore motor wire color and do a rotation test.
Matt
1% of the world's population can think "Outside the box". The rest are firmly stuck within the box. Where are you?
RC_Kiwi   10 µW
10 µW
Post by RC_Kiwi » Dec 13 2010 8:10pm
Hi.'
Am new to all this except the RC part. I did the Turnigy Modification but it does not appear to work. The motor does not respond to throttle input but slowly increases speed over time (i turned it off after 1min). However it works fine when plugged into a receiver etc. Using the turngiy 63-64-230Kv With Turnigy 85A ESC, a cheap hall throttle (I hope) Turnigy Servo Tester and on 22.2V (6S Lipo). Any Ideas? I may just have to buy a pot throttle although it is expensive. In New Zealand so shipping is not small either :(
Thanks
HumboldtRc   100 W
Post by HumboldtRc » Dec 13 2010 8:26pm
RC_Kiwi wrote: cheap hall throttle (I hope) Turnigy Servo Tester and on 22.2V (6S Lipo). Any Ideas?
Thanks
You have a BEC so the servo-tester only gets 5-6 volts? correct? Other wise you fried the tester with the 25volts....
RC_Kiwi   10 µW
10 µW
Post by RC_Kiwi » Dec 13 2010 8:55pm
Yep :D It does have a BEC. I'll take a photo of the setup
RC_Kiwi   10 µW
10 µW
Post by RC_Kiwi » Dec 13 2010 9:03pm
Here.
HumboldtRc   100 W
Post by HumboldtRc » Dec 13 2010 9:10pm
RC_Kiwi wrote:Here.
What esc are you using? Double check you mod to the servo-tester, mine worked fine, but i didn't like the throttle resolution. So i made a cable throttle box, with a 0-5k sliding pot, which feels like it has 2-3 times the resolution, then the hall throttle input.
RC_Kiwi   10 µW
10 µW
Post by RC_Kiwi » Dec 13 2010 9:13pm
http://www.hobbyking.com/hobbyking/stor ... duct=10331
I cut the pot off then soldered a jumper from the signal input to the middle pot connection? This was as per the mod on page 3. I can take a photo with the lid off it it helps?
fechter   100 GW
Post by fechter » Dec 14 2010 9:37am
You could try measuring the voltage on the signal wire while moving the throttle. Most hall throttles will go from about 0.7v to 4.2v or so (nominal 1-4v range).
You might need to add a resistor from the signal line to ground (10k?) Some hall throttles have this built in and some don't.
If the voltage on the signal line is too high when you turn on the controller, it might go into a high stick safety lockout condition.
RC_Kiwi   10 µW
10 µW
Post by RC_Kiwi » Dec 15 2010 3:34am
Hey. Thanks for that advice. I assume check the voltage across the entry/exit of the signal wire? I will check when I get some spare time. Not having much electronics experience, can I ask how you would put a 10K resistor from the signal line to ground? Thanks
Tim
fechter   100 GW
Post by fechter » Dec 15 2010 11:43am
RC_Kiwi wrote: Not having much electronics experience, can I ask how you would put a 10K resistor from the signal line to ground? Thanks
Tim
On the wires coming from the hall throttle, you would connect the resistor between the signal line and the ground line. You could possibly just jam the resistor legs into the back of the connector for a quick test.
RC_Kiwi   10 µW
10 µW
Post by RC_Kiwi » Dec 16 2010 5:37pm
Thanks for the advice. Well I was fiddling with the voltmeter and suddenly it worked! Turns out it was simply a dodgey solder connection (my bad :oops: ). Right I'll put the iron to it and see if it works properly. Thanks for your help!
Wheazel   10 kW
Post by Wheazel » Apr 04 2011 7:09am
The pictures on the first page doesnt show for me.
Did they disappear for some reason?
I have my servotester disassembled and ready to solder it to work with the magura.
Miles   100 GW
Post by Miles » Apr 04 2011 7:35am
Wheazel wrote:The pictures on the first page doesnt show for me.
I think they are a casualty of the recent transfer between servers...... hopefully, it's only a temporary problem.
bobc   10 kW
Post by bobc » Apr 04 2011 12:47pm
just thought I'd link to this alternative RC throttle interface. My mate is doing a version of it in surface mount so it can effectively be heatshrunk into the hall throttle wire: I'll post up the gerbers on here if anyone's interested.
http://endless-sphere.com/forums/viewto ... &start=360
near the bottom of the page ;^)
motomoto   1 kW
Post by motomoto » Apr 20 2011 10:25am
What is the deal with the pictures on this thread? Are they gone? I am trying to wire
up a throttle, but it's hard without the pictures. Is there some magic to getting the .jpg
to show?
AussieJester   100 GW
Post by AussieJester » Apr 20 2011 7:16pm
motomoto wrote:What is the deal with the pictures on this thread? Are they gone? I am trying to wire
moderator has just told you what happened to the pictures... :roll: -->
Miles wrote: they are a casualty of the recent transfer between servers...... hopefully, it's only a temporary problem.
[/quote]
I uploaded them again for you, these are series pics uploaded before by
Recumpence (Matt.S)
Throttle Wiring.jpg (133.25 KiB) Viewed 3774 times
KiM
etard   1 MW
Post by etard » Apr 20 2011 9:31pm
I just soldered my magura wires onto the legs of the Pot and left it there, it actually worked great as a throttle endpoint limiter as it was. I also used it as a temporary off switch to keep from accidentally twisting the throttle while I messed with other components on the bike.
Thanks for the pics Kim.
motomoto   1 kW
Post by motomoto » Apr 21 2011 2:48am
Yeah, thanks for the pics Kim.
I didn't get the memo.
Fietsbel   10 mW
Post by Fietsbel » Jun 11 2011 10:13am
Thanks guys for posting the turnigy servo tester - hall throttle tutorial, fool proof! (but not for me I guess)
I was kinda enthusiastic.. and just plugged the hall throttle in without swiching + and - poles.
I found out I made that mistake.. and corrected it, though it still does not work.
What happens if + and - are reversed, in terms of hall throttle handle..? did I burn something, discard the throttle, get new halls?
with 4 volt on the + and -, I get 0 volt on signal-ground, and 2,5 volt on signal and positive... Rotating the throttle does not change a thing... I fear I killed it?
Thanks!
opened it and this is what the sensor looks like... Burned it I guess.
The sensor states 49E .. at least the readable part.
Well, ordered these, we'll see: http://cgi.ebay.com/10pcs-Hall-element- ... _781wt_905
For those interested... some more reading that I found on how the hall throttles work... http://goldenmotor.com/SMF/index.php?topic=1718.0
Fietsbel   10 mW
Post by Fietsbel » Jun 23 2011 5:28am
Replaced the hall sensor, and it worked like a charm! thanks for the tutorial!
roxproductions   1 µW
Post by roxproductions » Aug 07 2011 2:49pm
Ok, I just gave this a try without removing the POT and it almost works... My ESC doesn't have built in BEC so I need to hook that up to the servo tester as well. I can use the throttle, but ONLY if I turn the potentiometer up a little first. Do I need to remove the POT then? Or should I hook up the external BEC to another part of the servo tester?
60 km/h dirt bike 72v 8000w QS3
40 km/h outrunner kick-bike
35 km/h outrunner longboard
60 km/h FS downhill x5404 20s2p
jawshnitzel   1 mW
Post by jawshnitzel » Oct 08 2011 10:11pm
i have been lurking here for years. and am now setting my bike up!!!!
i successfully ran everything with the turnigy servo tester on the bench. motor ran smooth, everything AOK...
since then i have made the changes to the servo tester for the hall throttle and am having no luck...
my setup:
-turnigy 80-130 motor
-CCHV160 controller
-turnigy servo tester
-i think my throttle is a hall style. i checked, no resistance changes when i turn it. it is a cheapo throttle.
-i am running a plug in 5volt power supply to the servo tester instead of a BEC (for testing)
-12S lipo 10ah 40c
i wired the throttle to the turnigy servo tester input (red +,,, black -,,,, white signal)
i put the jumper wire soldered between the middle of the old pot to the "S" on the input.
i wired the 5v power supply to the turnigy output (+ to + and - to -)
plugged in the CCHV160 to the servo tester
the sevo tester "manual" led lights up
now, the CCHV160 gives me the 5beep throttle error.............. and i cant see where ive gone wrong....
a few more things to add, it is possible that i got the 5 beep error because my plug from the CCHV160 to the turnigy servo testor could have been in backwards...... one direction gives the 5 beep error. the other does nothing. neither makes the motor go...
i read here someone talking about reversing the polarity (+ -) of the throttle leads????? burnt up the hall sensor???
am i heading in the right direction???? or can someone see an obvious flaw in my setup????? have i already burnt out the hall sensor and should take the throttle apart??????????? any direction would be a great help.
my bike is soooooooooooo close... and just before the snow flies... ah welll... would like to giver a try though before winter!
shnitzel
recumpence   100 GW
Post by recumpence » Oct 09 2011 6:38am
I have never run a hall throttle. So, I cannot comment. I have always used the Magura POT throttle. They work so well and are bullet-proof.......
I am sure someone else who is more familiar with hall throttles will chime in soon enough.
Matt
jawshnitzel   1 mW
Post by jawshnitzel » Oct 09 2011 12:22pm
im thinking of swapping the power wires on the throttle....... if it isnt already fried, it might be then... ha ha ha...
ill get some pix and start a build thread soon here. i owe it to all you and future spherer's for the education i got here myself!
i wont swap the wires for another hour or so... just in case someone sees something im missing.
shnitz
jawshnitzel   1 mW
Post by jawshnitzel » Oct 10 2011 11:10am
i double checked everything.... still no throttle. i tried to run the "auto" and "neutral" mode on the servo tester... it made the motor jump around wildly... so i think my servo tester is doing its job. i cant get any voltage out of the hall throttle. no matter what i do...........
sooooooooo, with no servo tester anymore to play with things. i ordered the magura setup described at the start of this post.... i wish i could have saved that$$$, but oh well.. this project is long past $$$$$$$$$$.... ha ha ha... ah well, all in the name of prototyping and fun!!!!
id still like to try and make this throttle solution work if anyone has any advice. my friend is replicating my bike, so if i do get BOTH throttles to work, ill pass one on to him.
shnitz
