Sometimes someone will want you to assemble a Frankenstein. They think they "got a good deal" by getting a controller, motor, and battery from three separate vendors. None of the connectors match, and the color-coded wires are all different colors. So...you have to figure out which combination of hall wires will work. I would charge extra if the kit parts are not all from the same vendor (except for the battery)
I'd charge $100 to get the kit together and running, but I would make it clear that no warranty was included or implied. If the customer takes the bike around the block on delivery to prove it runs, he pays and you never see each other again. Make it clear in the beginning, if anything stops working or goes wrong, it's not your problem. If they buy a cheap kit, they get cheap reliability.
No LiPo, ever. It's OK if you have a LiPo pack for yourself, but if it catches fire in your garage, or when you're riding...nobody will sue you. Even if there is no case against you, if you sold it to someone, and their garage burns down...you may have to go to court and spend time and money (even if you win the case). The only thing I would do to a battery pack is that I have often changed the main power connector to an XT90 plug/socket set.
Here's what I would do: show them the kits at em3ev.com, e-bikekit.com, and ebikes.com/Grin tech. All three of these vendors have a reputation for reliability. Have them select a motor/controller/throttle all from only one of those vendors (so everything has matching plugs and color-coded wires), Then have them select which battery they want. If the power plug doesn't match the kit they chose (typically Andersons/45A) then it is easy to take a 100W soldering iron/XT90 plug-set/6mm heat-shrink to get the battery/controller to mate.
Have them pay for the parts and be delivered to them. When everything arrives, go over there with your soldering kit and tools, assemble and get it running. Once they ride around the block, they pay you $100 with the understanding that any future trouble-shooting and repair will be $25/hr plus the cost of parts (which is what will get most of them to buy their own multi-meter/soldering iron/etc).
_________________________
I absolutely HATE customers. Nine times out of ten they are decent people who just want a product or service in exchange for the listed price. Its just that...the tenth guy?...I just want to smash his face into the concrete. Which (as I understand it), is still illegal here in Kansas.
If I was building turn-key bikes. My main model would be a CA-520 steel cruiser frame ($300), MAC 10T rear hub using 50V X 25A = 1,200W (28-MPH), 12-FET controller using 3077's, ($430 + shipping), and their small triangle battery using Panasonic 29E's (50V / 16.5-Ah, $700 + shipping)
Options would be Thudbuster seat-post, Cycle Analyst, cup holder, front disc brake using an Avid BB7 (stock would be Salmon Kool-stop pads). Total without options would be $1450-ish, but I would have to sell them for $1,950...to make it worth me smiling at them when they complain. And that's with no warranty on the battery.
