JBallard86
MK1
About a month ago i decided to weld up a skate board frame.
38" long , .5" square tubing with .0625 wall thickness. Mig welded together and welds ground flat on top and bottom. weight 9ish pounds.
So then I decided to add a 24 volt electric wheel chair motor (brushed of unknown wattage/working condition. I also added a 5000mah lipo pack, sabertooth 25x2 brushed motor controller and applicable RC components. It worked, barely. 15ish min of ride time 1-2 miles at about 8 mph, it was fun until I had to walk home while carrying it. When i got home after a 10 min walk I found that I had over discharged the batt (still seams to work fine though) and felt the motor it was scorching hot. My inferred temperature reader stated that it was in excess of 180 degrees...
[youtube]uTh2toq6quM[/youtube]
MK2
So I decided to order the following:
Turnigy Aerodrive SK3 - 6374-168kv Brushless Outrunner Motor
Hobbyking SS Series 190-200A ESC
I then fudged up a quick and dirty motor bracket, sorry no pic it was quick and dirty.
Needless to say I was very disappointed, using a 9:35 gear ratio all I got was cogging from a stand still, even with some moderate pushes it would not start. It would zip across my yard incredibly fast, but not with me on it. It would with my 9 year old little brother sitting on it though (after a push start.)
MK3
Well this one is in the works now I have ordered a second motor and a second ESC I also ordered 20ah of LiFePo4 batteries to keep me going once i get it all right. I also ordered 2 40 tooth sprockets for a 9:40 gear ratio.
thats a 20AH 8s setup I figure it will be fine since it is about the same charged voltage as a 7s lipo which has been my test battery.
I have fabricated some new motor mounts out of stainless, just waiting on the right wire so I can weld them up, and I will post pics of them.
I have my doubts with these ESCs I think I may end up going with the Alien Power Systems 125x2 ESC for EV vehicles. also it needs to push around some weight im 230lbs board with all batts/electronics is a beast at 30ish pounds.
More to come, please offer advise or ask questions.
MK2
MK3
