agniusm said:
Yeah, but was actually been shifted to over 84V? Swapping caps is easy if it can do it. I would very much like to have 1 psu for the size but i thing 80 is a long shot
I'm not totally sure if i understadn those written lines correct,....
I was bored today and tried it on my !Eaton EPR (900Watt-Version)! -> without load
EEprom-> set to 40 Volts (but it will just allow 43 Volts minimum)
so...lhe lowes i can go with my additional Potentiometer-Mod ist 40,6 Volts
The highest is 90 Volts and potentially above, but i just had a quick look how high and stopped at 90 cause i was afraid caps could pop
I clinched my EPR housing together again so i do not want to open it again to see what Caps are built in, but i Guess it will be 63Volt Caps
i guess you read the "introduction" to this thread
First trace(marked with red cross) is for over-voltage protection. If you do not cut it, the PSU will shut down when voltage goes above 57.5-57.6V.
If your fully charge voltage do not exceed the 57.5V you don't need to cut it.
I do not have my programmer by hand now, so I'm not sure if i would be able to programm the Voltage higher than 58 Volts.
Like i said with my pot-mod its possible to crank teh voltage up really high (> 90Volt )
