QSMOTOR,0.5-12kW Electric Hub Motor & Mid Drive Motor Manufacture China
madin88 said:
such heavy hub needs a big tire at least if you place importance on rinding comfort. a big tire needs a big rim, and 1,4" would be only good for maximum 2,5-2,75" or 70mm wide tires.
on my holmes 1,6" rim i run the bridgestone battlax 80/90 17" tire. this is a racing tire with very soft compound optimal for heavy hubs^^
madin88, I am going to disagree here without really saying I am right as I don't know for sure.
A wider rim I believe is needed for more contact patch for straight line grip. This is important for motored bikes with a clutch. This however is not important for our low powered ebikes without gears.
The 1.6 rims add a good amount of weight compared to a 1.4 rim. The straight line traction is not needed so having a wider rim is a total waste.
I agree with you about the large tires and I run 17x3.00" shinko 241 tires at 12-14PSI and those were a dream for the heavy hub motor. However, I surely don't need a 1.6" wide rim for those.
SO yes the tire will be more rounded with a 1.4" rim, but I believe that isn't a problem at all as traction is a non issue. Plus with the 1.4" rim you save a large amount of weight in the area which has the most impact on performance, and this is very important for our ebikes.
I already tried to get Holmes hobbies to convert over to the 1.4" rims, but he says he has to sell out his 1.6" first.
The 1.85 is a beast. I think the 1.6 is fine but offroader is right, 1.4 is much lighter. I like the profile of the 3.00 tire on the 1.6.
the weight difference between the 17x1,6" holmes and 17x1,4" prowheel rim was only about 0,3kg IIRC. between different tires the weight varies alot more. as the rims from holmes are the only ones available from what i know which have the optimal spoke angle, it is the only choice for me. if you have 20" or larger moped rims, the angle would be ok, but who uses such large wheels?
Wow. I didn't realize the 1.4 and 1.6 were so close in weight.
Also, when you get into wider rims, the selection of the lighter 2-ply tires might be fewer and less desirable. The majority of the wider tires seem to be the heavier 4-ply (from reading, no hands on).
Of course, even if there is only one tire choice available, and it's the type and size you like...nothing else about the rim matters.
Ok I think I will go for the 18"x1,85" one on the rear and 19"x1,6 front. Thank you all for your help.
-Regards, Elias
Hmm maybe it is time for a dedicated tire thread? *Where we could over time collect all needed data, like weight, how many ply each tire has, actual width as that tends to vary a bit from manufacturers. As it stands now the info on tires are scattered over various threads. Would be nice to have one-stop thread for tires.
Anyone up for the task that already has some info to share? If I was to start such a thread without putting anything of value in the first post the thread would get buried pretty quick in this forum, so it would be nice if someone with lots of experience with tire choices would start the thread.
@Rix, @spinningmagnets any of you care to open the ball?
A wiki function would be great so it isn't all upon one person to manage it.
Sure wiki would work too. Hm I seems to forget about that wiki. :)
If someone feel they could get the Wiki started, here is the main page: https://endless-sphere.com/w/index.php/Main_Page
Even if one person starts the tire thread we can chip in with additional information and share our experiences for the benefit of the ES community.
when comparing 17x3 tires, the IRC (2ply) actually is 0.5lb heavier than the Shinko(4ply). i think it is strange more ply but less total weight.
but i think 0.5lb is too minimal to even care
Got my motor today, thanks Vito and the girl with the Hello Kitty smart phone case.
The motor came Fedex in a sturdy box of 1/4'' thick corrugated cardboard with reinforced corners, plastic handles and heavy strapping. Inside was a block of styrofoam formed to the motor. Very good packaging and I can't wait to get this thing on my scooter.
72v_5kw_12inch_motor_box1_zpstnmzpzpk.jpg~original
72v_5kw_12inch_motor_box2_zpswwytzbvu.jpg~original
72v_5kw_12inch_motor2_zpshamtawax.jpg~original
Hello Mistercrash/Raymond,
Thank you for your positive feedback, it's our standard package, also for 205 spoke hub motor.
Btw., it's DAISY Duck in the picture (Q Style), Donald Duck's younger sister. : )
Best Regards
Dear all,
Latest News 2015.11.26
We're going to make 10pcs QS 3000W 205 50H V3 Spoke Hub Motor, 72V 650RPM in store. Estimated to be done within 7-10 days.
Once place the order, the production time will be much shorter for samples.
Maybe we could send out the motor once we received the payment in near future.
For more information about the motor, please refer to beow link.
https://endless-sphere.com/forums/viewtopic.php?f=31&t=65972&p=1082427#p1082427
Best Regards
QSMOTOR said:
Dear all,
Once place the order, the producetion time will be much shorter for samples.
For more information, please refer to beow link.
Best Regards
nice, would you be able to provide it laced in a moped rim? So that I can put that on my bicycle with freewheel but good nice moped tyre to handle the motor weight and power.
cwah said:
QSMOTOR said:
Dear all,
Best Regards
Thanks for your interest, we will keep bare motor in store firstly.
The rear wheel set could be customized due to detailed requirement (19X1.6 18X1.85).
For details about laced in moped rims, Please refer to below link.
https://endless-sphere.com/forums/viewtopic.php?f=31&t=65972&p=1102374#p1102374
Best regards.
Who is ordering a 1.85 rim? Don't you think that is kind of too heavy? What size tire do you expect to run on that?
1.85 rims are like 4 or 5 lbs.
Im going for one! 19"x1,6" at the front and 18"x1,85" for the rear. I like the design more and also some people told me that the 1,85" version is lighter. I don´t know why but that´s what they told me.. :roll: :D
Mammalian04 said:
Hi DasDouble, if I have said that the 1.85 is lighter, I didn't mean to. The 1.85 is quite heavy.
Ok thank you for this correction. Anyway. I don´t think that it will matter that much. Will use it most if the time on street and if I need to then to escape from police across some fields or through the forest :mrgreen: :lol: :pancake: 8) :roll:
Even being heavy, it will be ok. I have a 19x1.85 (fuzzy math says about 5% heavier than the 18") and it is not bad. Doesn't tear it up and wheelie quite like my 17"X1.6 but it is perfectly fine for most riding besides the pretty steep stuff. Even then, just get up on the pedals and help it out some and you are generally ok.
