Bms clarity
dmarquez960
Most bms ( battery management system ) come with B- , C- , and P- ports. Battery negative B- , Charger negative C- and Power negative P- . This bms has P- and P+. My question is where does the charger negative (C-) gets connected to. Can someone please help me 🙏 Thank you very much
This one looks like a single port. You charge and discharge through the same port. Charger goes to the P+ and P- connections in parallel with the output.
100% correct.
