thebruce
🔌 New-ish
Hi there - first post here. My boys (14 and 12) are stanning on Super 73s, Surons and Talarias. I told them I would only consider the expense if they learn how to spec, build and maintain one themselves. We've built computers before and I have an old boat and 911 they help me work on so felt this would be a good boys bonding experience. I had some questions (and would love any feedback) from the pros here before we jump in. Sorry for all the questions in advance
Our inspiration was this build from ROOK. He did some epic work. RooK on Instagram: "#zeromotorcycles #stealthbomberebike #enduroebike #customebike"
1. First, we are looking at the Enduro frame with 20x4 moto wheels. This seemed like the lightest frame and would be something they can continue to customize.
- Is that what most of the cool kids are doing these days or is there something newer out there?
- if installing 20x4 fat tires we would need a 170mm frame and 170 hub right?
2. For the motor and controlled I wanted something that wasnt too fast for them at this age but they could upgrade when they get older. Im talking to NBPower (which ive read some good things about from other people's builds) and I was debating two kits:
- option 1 a 2kw hub kit: this was my original plan as lower cost and slower speed (and cheaper at ~ $440). But NBPower said for a 2kw motor you could use a cheaper downtube battery (~$400) - but that wouldn't fit in the enduro frame...
- option 2 a 3kw hub kit: so they recommended a 3kw motor for ~$610 and 72v 20ah battery for $680. comes with a Sabovoton controller. they said the 150mm dropout motor is a QS but the 170mm is their own "NB" brand and the battery is Chinese 2170 cells.
My questions are what do you guys think is the optimal motor + controller + battery size for younger kids that hopefully could be upgraded as they get older. Would you always have to replace the battery and controller if you are upgrading to a larger motor in the future...?
3. I have researched other peoples builds and think I have most all the major components: frame, motor kit, battery, suspension, etc. But I dont know what I dont know and there are some areas im not super clear on:
- what additional hardware would be needed for the front fork assembly (that would not be included with the fork kit): bearings, etc?
- for the drivetrain do most people just use a single gear (seems simpler) or install gears, de-railers, etc. any recommendations there.
- besides the motor and controller kit, what other parts are typically needed for the electronics?
- any recommendations on mounting the controller and battery in the enduro frame. ive not found any info yet on best methods to secure the battery and controller.
Sorry for the detailed questions. I hope to post project updates as we progress.
