michael.jahrer
New here
- Joined
- Jul 25, 2020
- Messages
- 17
Hi,
Basis is an German Kalkhoff all-round men bike 28", which I bought used several years ago for 150€ or so.
Focus was cheap, good power, durability, quality and minimalism.
The build took me several months of buying, planning, making, testing.
I had some prior experience in building different electric powered equipment.
At the end I am pretty happy with the eBike, it can accelerate silently to 50kmh ~ 30mph with the 1kW motor at full load, while being fully functional.
The controller that comes with the kit does not provide regen and is loud (square wave), I tested the bike a few days with this one and an other battery.
The VESC is much better, smaller. I set max. current to 20A to and from battery. The rest is standard auto.
Regenerative braking works good, at steep hills it send back -15A to the battery.
I notify the added weight at the front wheel when riding over bumps, it is not that smooth as it was before.
The original front/back light is still functional switchable, power supply is the 5V output of the VESC.
2000Wh battery (the "highlight"):
I figured out that the angle of the frame is nearly 60° at the crank, this was the kick-off for the large battery.
High capacity cells were available at nkon for ordering. BAK N21700CH-58E - 5750mAh (~20Wh).
13S8P would be a nice number to break the 2kWh barrier
First I bent a stainless steel band int right shape and I welded 16x M5 screws for the mount to the frame.
While mounted I spot welded the cells to the complete 13S8P pack. This is important that every cell fit its perfect place.
Front, back panel were TIG welded while the band being mounted. Then I carefully removed weld residuals by grinding.
After post welding all spots I added a balancer connector, no BMS.
Complete battery has 9.08kg, cells pack alone 7.63kg.
When attached to the frame the construction fit is very strong. The box is rigid, no movement at all.
I covered it with a bathing cap to be rainproof.
After the first longer ride at full throttle the VESC (which is mounted on an aluminium 4mm sheet) does only get a little warm.
Hub motor also got warm. But not dramatic.
I ordered several components from aliexpress, battery from nkon, metal and epoxy sheets from amazon.
Other parts like throttle, brake, connectors, cable etc. were found in my garage.
Anti-spark switch: https://de.aliexpress.com/item/1005007582347642.html
Battery meter: https://de.aliexpress.com/item/1005005356586078.html
Speed controller VESC: https://de.aliexpress.com/item/1005004275900738.html
Front wheel hub motor: https://de.aliexpress.com/item/1005009015247450.html
21700 cells: https://www.nkon.nl/en/bak-n21700ch-58e-5750mah-11-2a.html
Best Regards from Austria,
Michael
Michael
