I'm gonna carry mine in the back of my Cybertruck, loaded on the flatbed of my Tesla semi, loaded on a rail flatbed pulled by the yet-to-be-announced-Tesla-railway-engine!When y'all receive them, are you gonna carry your bikes in the back of your Cybertrucks?
Please PM me with your name and I'll check.I am waiting for mine, and bike is also ready![]()
Me too! PM sent.Is there anybody else here who's waiting for the motor?
lol...I thinkI am also waiting for mine since 04/2020…
Just received my kit! And it is the first day of my vacation, so it must be a good sign
Let the bike building process begin!
What kind of bike are you mounting that on? I see an ISIS spindle, what width is your BB?Just received my kit! And it is the first day of my vacation, so it must be a good sign
I received a shipping notification today![]()
Cool. I hope to see some installs and road test results here soon. Depending on how they turn out I might have a hard look at one of these for my gravel/road bike, now that I have canceled my second Photon order. Although I still may get another Photon if and once my issues with the first one are satisfactorily resolved. We'll see. And I am Italian descent.![]()
I'm definitely gonna be behind the curve because i want to fit it to 1 of 3 semi-recumbent bikes and i may have the wrong parts from the get go / who knows about how this will fit!
Looking forward to seeing what others build ^_^
The kit is for my Turner Burner 27.5 with 73mm threaded BB.
The BB assembly came in separate parts, so now I have to figure out how to put it together correctly
So, I have spent half a day trying to install this creation. Without luck, unfortunately. Here are the reasons:
1. I can not even turn it on to check if it is alive and play with settings. Why? Because I have not received a tiny power connector! And response from Bikee is hilarious.
This thing retails fot less then 2$. Have Bikee decided to maximise their profit by such decision? I really doubt this is reasonable.
BTW, abeugabeluga have received it, judging from the photo.
Also in this letter I informed them, that safety rubber is also missing. According to manual(page 33), it should be placed between frame and motor. They completely ignored it. Well, I will have to make it myself from old tube.
2. As I mentioned earlier, the BB assembly came in separate parts. There are 4 bearings, 2 caps, 2 rings - spacers and axle. No instructions how to put it together and no markings, what is for left side and what for right. In the manual there are some info about square BB, but it looks diferent.
I had to use bearing press to install bearing to right cap, others went in by hand. If I install 3 bearings, axle moves about 5mm. If all 4, I can not tighten caps. Which is no surprise since bearings are 7mm. The rings are 4mm and are too small for the axle. I can try to heat and press by force, but do not want to do it before I get clear instructions from Bikee.
3. When I made the order, there were only 2 options for mounts - short and long. I ordered both. Now they have more variants.
Today I tried to install the short one, bit since the down tube is slightly bent, it did not fit. I changed chainring from 36T to 32T, but it did not work too.
View attachment 337419 View attachment 337420
I guess the short mount only works with straight down tubes. Will try the long one next time, but first I have to buy another chain to make a really long one. And then contact Bikee, maybe one of their new variants will fit better.
The connector is for motor, not battery. No power cable is coming from motor, only tiny socket for this connector.I kind of understand their answer about the connector. Motor makers have no idea what kind of battery connectors users have. As for the rest, I am glad it is you taking one for the team is trying this out. Please keep posting your progress.
I bought kit with superhero, but can not test it untill I get the power connector.My motor should get delivered tomorrow.. Is anyone is using Superhero pack? I wonder if the settings made are stored in the motor so i can setup it once and disconnect the mobile?
Sure, I will post how it goes.
