fededamiano
100 µW
Hello -
My ebike has an s830 LCD display and is speed limited to 33.8 kmh (regardless of including a higher value in the P08 setting).
The controller is as per the pic attached.
I have opened the controller and there does not seem to be any cable looping back to the controller (ie. speed limit cable) however it is hard to see as the cables are bundled into group connectors (rather than other DIYs I ve seen where each set of cables are separate).
Any hints on how I may be able to overcome the speed restriction?
Thanks in advance
Thanks in advance
