There's pics in my SB Cruiser thread of most of (minus the snapped off axle ends) a QS205 50H on a scale; not sure if any of the pics show the whole thing at once so you might have to add up the weights.
EDIT: found the post here, says whole motor was 29.38lbs
Funny you shoudl say that... :/ Tonight, I had the problem again, while just sitting at the traffic light waiting, the lights went off, then came bakc on, stayed a few seconds, went off, falshed on and off a few times, then went out and stayed out. I tapped and whatnot on various areas I coudl...
endless-sphere.com
There is also some data in other threads, like this one
Is it the same size motor as the 50mm with smaller stator and magnets for a 45mm. I need and try to get the information if it's a smaller unit and how much less it might weigh. That 205 50 mm motor is quite heavy for an e-bike. Both have 150mm dropouts ? Same shell ?
endless-sphere.com
endless-sphere.com
EDIT, oh, the post I was looking for was linked right after those
endless-sphere.com
I thought I had actually measured mine at 150mm, but I don't see anything showing that; I think my own note in the post above is just from the QS specs.
