Kt controller brake sensor
GaSSoo
Slovakia
Hi. I'm trying to connect brake sensors to kt controller. On 1t5 cable brake sensors is 3 pin male. But my brake sensors connector is also 3 pin male. Cannot find sensor with 3 pin female so I bought 3 pin female connector with 3 wires on end (y, r, b). I cut brake sensor and there is also 3 wires but one is different color (white instead of yellow). I tried to connect wires (b-b, r-r, y-w) but it didn't work.
I will be thankful if someone know how to connect this.
Hi. I'm trying to connect brake sensors to kt controller. On 1t5 cable brake sensors is 3 pin male. But my brake sensors connector is also 3 pin male. Cannot find sensor with 3 pin female to I bought 3 pin female connector with 3 wires on end (y, r, b). I cut brake sensor and there is also 3 wires but one is different color (white instead of yellow). I tried to connect wires (b-b, r-r, y-w) but it didn't work.
The KT controller only uses two of the three wires (signal and ground) for the low brake cutoff. If you have a multimeter, you can check the pins on the cutoff connector to find which two short when the lever is pulled. On the controller side, identify the ground wire with the meter, which should connect to one of the two wires you identified already. The signal wire on the controller side will usually have a pull up resistor to bring the voltage up to near 5V, so you can use your meter to identify the wire, or you could just try each wire to see which stops the motor.
I don't have multimeter but I found red-red and black -yellow works. But it also works the other way R-Y and B-R. Does it matter how I connect it?
Can I connect third wire also?
It shouldn't matter since on the switch side, neither wire should be grounded, just an open/closed circuit. You shouldn't need the third wire.
Do you know if or how the rim brakes can be setup in a kt controller? I mean, how is the cut out on the motor done if you use a 2-1 cable with no brake sensors?
I'm in the research process to do a build with tubular kt controller under th seatpost to do a bike like the roadster
Thanks for the help
Thanks for the help
perhaps list the items on your shopping list with links? the only 2 in 1 cable google and I know of is the extra brake connector splitter usually used for adding a gear change cut off for bafang mid drive builds.
your controller should have a Normally Open pair of connections for brake cut off, frequently 2x, all the sensors do is close this connection when the brakes are applied hall sensors and magnets are generally used with hydraulic brakes and folk have used everything from blutak to epoxy to set the magnets in place .. lots of youtube how to's too ;) many sensors can be connacted to the same input any closing of the connections will activate the brake cut off.
