1st of: I'm proposing an Experiment:
I'm not recommending anyone try this on any bearings or chains they are not about to replace anyway.
I have tried this in car engines, where there's a lot of heat, turbulence and WATER (HC+O2= H20 via blowby) in the engine oil.
The 1st one was near death and about to be reconditioned. There it worked... lets go with well, as miraculously sounds too good to be true.
Let's say; so well that I expect it will lower rolling and pedaling etc resistance to a noticeable degree.
In a bicycle bearing or chain I expect the (experimental) process to take much longer for the reqd reactions to occur and the treatment to 'take'.
So 1st the patent:
Now that's WELL into 'Too good to be true' territory!
So who-TH is the patent holder; Dr Ali Erdimer!?
I found this on the US Dept of Energy's website.
I have posted the 1st couple of pages below.
Here's the link to the complete presentation;
https://www.energy.gov/sites/prod/files/2014/03/f13/vss_17_fenske.pdf
Parasitic Energy Losses
NB the "Emulsion of Boric Acid" in Oil..!
Here is another link showing a test engine used in these experiments etc;
https://www.energy.gov/sites/prod/files/2014/03/f11/merit08_fenske.pdf
There is one hell of an argument (for your amusement
) with links to tons of research here:
BORPower additive? - Page 3 - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com
(uBlock Origin is a browser extension that will clean up all the ads etc in the above site)
This post is just to gauge interest.
If anyone is interested in testing plz do post so we can get into various ideas on how best to treat bearing and chains etc to do so.
(A velomobile would be ideal, so that aero drag has less influence on results. Electrified would mean that one could see any reductions in reqd power and increases in range)
So 1st the patent:
"This invention was made with Government support under Contract...awarded by the Department of Energy.
The Government has certain rights in this invention...
...the most preferred...particle size for boric acid is from about 0.2 to 40 microns to facilitate the formation of a stable suspension with the boric acid being present in a amount of at least 0.1 to 0.2% by weight.
The amount of solid particles that can be mixed and/or dispersed in the oil will be dependent on the size of the particle. The smaller the size of particle, the greater the amount of particles that can be suspended in oil.
... the most preferred range being 1-15% for oils and 1-20% for greases.... [by weight]
...a mixture of boric acid and an oil lubricant, the friction coefficients are reduced by 10 to over 1000% below those of the unmixed lubricant itself. The wear rates of pins are reduced by factors of 50 to 100 below those of pins tested in unmixed oil itself..."
US5431830A - Lubrication from mixture of boric acid with oils and greases - Google Patents
Lubricating compositions including crystalline boric acid and a base lubricant selected from oils, greases and the like. The lubricity of conventional oils and greases can also be improved by adding concentrates of boric acid.
patents.google.com
Argonne’s Ali Erdemir elected to National Academy of Engineering for pivotal discoveries in tribology
Distinguished Fellow Ali Erdemir from the U.S. Department of Energy’s (DOE) Argonne National Laboratory has been elected a member of the National Academy of Engineering (NAE), one of the highest professional distinctions accorded to engineers.
The NAE recognizes Erdemir for his distinguished contributions to the science and technology of friction, wear and lubrication. Erdemir, a program lead in Argonne’s Applied Materials Division, develops new materials, coatings and lubricants with his research team to reduce friction and wear, maximizing efficiency and durability in moving mechanical systems. The discoveries and innovations stemming from his work have earned him six R&D 100 Awards and 23 U.S. patents.
