Hi,
I have a Bafang M400 with a probably broken controller, so I ordered a replacement.
However, this bike is fitted with Enviolo Automatiq, and somehow the older controller had one more cable,
which the replacement controller does not, so I cannot plug in the Automatiq.
My question is, how would I power the Automatiq using the Bafang M400 controller? It needs a between 9V-55V power line,
and I just cannot find that much information. There are two loose cables from the controller, I think EB-BUS and maybe gear sensor?
Enviolo has an open-ended cable for sale, which means that it would be a matter of figuring out where to actually connect it and connect
the correct head.
The old controller came with a XTU30U-F cable
Thank you if you are able to help with this dilemma.
the correct head.
