narakutaishi
Hello all,
Long story this one,
Bought a used stealth bomber clone 8000w T5, 150A Sabvoton controller, 72v 24ah battery with all other wrighting on this unit in chinese worked for my daily commute for a year in all weathers, plenty torque and would pull all the way up to 60mph. Never skipped a beat and always guaranteed a smile!
Was heading out on it one day coming up to a corner I locked the back break up coming in to a corner (no cut off switch in break leaver, hope tech 4s I'd fitted myself on this bike) the motor made a heavy grinding noise and the controller knocked off. When I turned it back on there was no green light on the controller but the screen came one.
Bought a new 8000w motor and controller
8000w T3 motor
150A Sabvoton
Realised the battery BMS had blown, so had the battery balanced and the BMS replaced like for like with 150A unit
I've put it all together and it just kept cutting out when I get to certain speed and I have to disconnect and reconnect the battery to get it to go again. I have found some settings for the MQCON app from someone programming the same size motor and controller on yiutube. It's definitely better but still cuts out at a certain point.
So I'm kind of stuck here,
The setup I originally had felt bulletproof, could keep the throttle wide open all the time, it never let me down till the day it did haha
Any help would be much appreciated!
8000w T3 motor
150A Sabvoton
