Another day, another very interesting paper:
They used pulsed AC to make it much easier to find plating thresholds for different cells.
It's quite accurate (within 0.1A), but its downside is that for higher power cells, low currents aren't anywhere near as accurate since these cells are built to be much tougher in general. Plating currents are much higher and an AC charging algo will cause reversible plating to happen, making measurements much more difficult to get.
I would heartily recommend reading page 5 and 6 as that's where all the juicy information is located.
Panasonic NCR18650B lithium plating current at
-10°C = 0.15A (0.04C charging current maximum before plating happens).
Sony VTC6 lithium plating current at
-15°C = 0.8A (0.25C charging current maximum before plating happens).
-20°C = 0.4A (0.12C charging current maximum before plating happens).
On that note, I believe I should stop posting scientific articles(even great ones), unless they're truly groundbreaking and will be implemented commercially. I'll probably make a thread in the next few weeks on the subject.
