Controller wiring diagram needed
asbrown75
brisbane
Hi
I have just purchased a new 1500W bike controller but it doesn't come with any instruction . looking for hep to connect the controller up.
Pvcqjkd 48V 60V 64V 72V 1200W 1500W 18 Tubes Brushless Controller purchased from amazon​
Thanks
I just bought the same, and I got this sheet with it (#3 wire is white).
And given this is one of the only results on the web, and I just found the attached, thought I'd add here.
It seems to be a JIANNUO Controller (KSHG372 Model - 1500W 18 Tube).
See attached: 1. Diagram, 2. PDF of the text on the diagram.
  • PVC Controller Manual.pdf
I need wiring diagram if someone have of this conntroller?
3x phase wires are easy to ID, as is the battery connection. and the 5x or 6x wire block of motor sensor inputs should also stand out.
that leaves just the display and sensor connections, 3x wire connections if connected are probably reed switch brake sensor inputs,
the display connector will have 4,5x or 6x connections..
Pas, throttle, and hall sensor brake cut offs are generally 3 wire connections and can be tested via trial n error with no problem.
Any connections left over photo and post..
Get stuck in...
