Ebike stutters for a sec then spins in forward, but runs smoothly in reverse. Is it a wrong phase wire combination?
Nazan
Kerala
So I recently changed my ebike controller ( dual mode both Square and sinewave supported) and when I did the connections and the self learning and everything was smooth. Then while cruising all of a sudden the motor staterted jerking and i stopped the vehicle when I gave accelerate it became Square Wave. So I changed the wire combination and did self learning again then I became sinewave. But now the motor jerks for a sec then spins which causes the motor to not turn at hills until I give a small push. But in reverse it give instant torque smoothly. Any idea why?
Ok. If I can change the motor direction then that's fine. Cause in opposite direction it perfomanc3 really good. But my question is would it damage the motor. Mine is a direct drive
You still didn't reply to my question. My question is would the motor get damaged if the direction is changed from how it used to spin. What I mean is that my motor the brake is on right side and it moves forward. So can I just change the motor side like turn the motor so the brake is on left side and do self learning to change motor direction. And If I do that would the motor get damaged. It does work like that.I tried but I am scared it would get damaged
