Hillhater
📜 Mega legend
The perenial question, !…with no definitive answer to date
…converting an RV house battery system from AGM to Lifepo4, and charging options..
most current Lifepo4 12 v batteries (100/200+ Ah) claim to be able to charge from existing RV alternator system (14.4 v),..and there are lots of RVs that have used that effectively.
but.. many installers suggest an expensive ($3-400) dc/dc charger is required to full charge (14.6 v)
if a solar charger is already installed also, ( PWM with a 14.6 boost charge function) ,would that not effectively “top off” the charge if the alternator voltage is not quite enough ?
Is the DC/DC charger really bringing anything to the party….other than expense ?
EDIT. Has anyone tried using aa solar chage controller as a dc/dc charge controller ?
IE,..simply inputting alternator output dc in to the solar panel input terminals ?
