Votol Phase Current value
rbarrow
New here
Looking at page one of the software, there is a value called Phase Current at the bottom of the first section. It is clear that this value represents a parameter/register/setting for a model of controller. They tend to differ model and model and sometimes older versions as well. I have listed a few I have confirmed as default, however, I would welcome what you have seen as default on your controllers. I have pasted what I know below. If anyone has any idea as to what these values mean, such as if it is a calculated value, please share:
Old EM-100 9000
New EM-100 9960
EM-100GTR 9000
EM-100GTS 10826
Old EM-150 9200
New EM-150S 9960
EM-150/2 9960
EM-180GTS 9000
EM-200/2 8800
EM-260 9960
EM-80GTS
EM-50 9000
EM-50-4 9000
EM-30 7800
EM-550 9960
I had a EM150, I was able to turn it up to something like 11000. It was supposed to be 540pA if I remember correctly. Maybe it was 10800?
What's an "increase ability"?
In the software. How do you know exactly how many phase amps your are running? For instance if you are on the second page and have initial phase at 9000 and peak phase to 10500. What would the phase amps be considered?
I don't see the peak phase current value in the UI. Where do you see it?
My 260SGTP came with 8600 in the phase current value. I'll try raising it soon.
In my setup (EM-150/2 with QS138 70H v1), the maximum phase current is set to 9920 (manufacturer’s default).
Can I assume that the start phase current uses the same value system, and that a value of, say, 5000 won’t damage the controller? Right now, it’s set to 3800 on my 4kW moped, and I’d love it if I could start it with the rear wheel spinning. Right now it starts up fine, but a wheelie isn’t possible.
