Dapu m155 geared hub motor.Dapu website m155 is 250 up to 500 watt.Anyone use this motor with more than 48 volt?
James340
Aguila Arizona USA
The Bike manufacturer rates it for 350 watt with 36 volt battery.I am running it with 48 volts.The added voltage really perked it up.Higher voltage would allow higher speed with less amps?I don't want to destroy it but would like more speed
more speed takes more power; check the simulators at ebikes.ca
Yes, the motor will spin faster in direct proportion to the voltage, but it also needs the power to reach the higher speeds. If you don't give enough power for its higher speed, it'll run inefficiently and get hot, but if you give it too much power, it'll also run hot anyway. It'll probably be OK for around 1000w from the battery - say 18A at 52v. It all depends on your rides. It won't be any good for off-road stuff or steep climbs at much more that 48v.
I have been experimenting.I rode 3 miles using 600/700 watts@48 volt and the motor was not even warm.Dapu said it has 45Nm of torque.Hills really stressed it @36 volt
Probably it'll be OK @ 52V (58.8V fully charged for 14s), but check the controller; it may "cap out" @ 60V, so I wouldn't exceed that. Depending on the rear spacing and wheel size, you could replace the motor with a direct drive kit for $200 or so and really increase the performance.
Controller has 100v caps.I pedal this bike alot&DD hubs really slow me down.Right now I have a 13s 3p battery on the bike but I have some cells&was thinking of adding in series 3s 3p.I really like this little motor
No motor has torque because it's a variable that depends on external parameters, like volts, amps and speed. It's more or less directly proportional to current and voltage. Stepping up from 36v to 48v gives an instant 30% increase in torque. If they quote a torque figure, they have to qualify it by mentioning the speed, volts and amps.
