Tsdz8 motor : what modern 29er will motor fit in
England
Hi, new member
I’ve built a 2010 orange 5 with a tsdz8 out of second hand bits. Done 500 miles cross country but started doing some more hardcore downhill and the 26” wheels are really starting to hold me back, rolling over stuff on the technical sections
So my question is what modern 29er downhill bikes have a 68-73mm bottom bracket that my motor will easily fit ?
I have a Whyte s150 on loans from my mate at minute I was thinking of buying it, but the suspension pivot is too close to the bottom bracket for clearance on the motor
The only one I can think of is a modern orange 5/6 with 29” wheels as the pivot is about 60mm from the bb
I’ll consider anything if anyone knows of any modern DH that will work with the tsdz8
Pic of my current orange 5 26er
Not a DH frame but what would your thoughts be on the Boardman MTR 8.6 which doe's take a TSDZ2(B) along with a under slung battery, it takes taper forks, the photo shows mine as mullet 29"f / 27.5"r but have switched a 29"r in at the moment as the 27.5" rear hub has broken up. Do not know how different size wise the TSDZ8 is, thinking of buying one myself or you can do what I have done go mullet, the second photo is my 26" Boardman, 27.5"f / 26"r combo with Lutu 27.5" air forks, changed the head angle slightly but great ride, otherwise I would have fitted an offset bush(s) in the rear shock if needed. Finally yes, I have done a mullet 29"f / 27.5"r with a 27.5" frame, again fine ride as the frames are all NOS and could take a slight slacking of the head-stock angle.
You will have to be careful with Giant frames, it's a bit hit and miss I have used Anthem frames but came unstuck with a Trance frame and had to fit a rear hub drive to it due to the framing around the BB. Also myself I avoid carbon fibre frames as I use M5 thread inserts for battery mounting.
The Boardman MTR 8.6 I have is fitted with a 48V 7ah which has gives me 30 mile max range on the flat with some hills which suit me fine as it gives me a light weight bike, I do have a long range Boardman Team FS 27.5" fitted with a 14ah battery running on 26" wheels with Trail King 26" x 2.4" tryes.
have you considered a hard tail? if I wasn't abroad I'd go buy this, stupid cheap, it's got a 66 degree head angle , virtually the same as the Whyte......and run it with as light a battery as poss....
i'm no expert but I know guys say a modern 29er with a slack head angle has moved the game on for going downhill on a hardtail...
The bikes are a scratch build from the ground upwards using a NOS frames mostly with a TSDZ2(B) mid drive, I have been using the small water bottle batteries either a 48V 7ah or a 36V 10ah brought thro Aliexpress, I seem to have a problem ordering now from there, so may when I need another contact the supplier by messaging them. But PSWPower are doing this. There are others on Aliexpress depends on what you want, there are ones that fit into a bottle mount. I have not got the patience to build a battery unless I really had to. Forgot to say the $140 included delivery to me.
  • Screenshot 2025-05-31 at 18-09-09 EU no tax Electric bicycle Battery Hailong G70 18650 Cells P...png
frenchie: prefer full suspension as I have very old bones, do have a Boardman MTB Team 650 hard-tail built as a 29.5"f 27.5"r for the grand son, he's not really bothered so may put a old rebuilt TSDZ2 into it.
Hi, new member
I saw a Bbso2 in the new Ozark trail full suspension bike, chainline was really good motor did hang a little lower due to frame design.
i hear you!! not as young as I used to be myself :cry:
I gave up mountain bikes some years ago, as even then it was hurting too much when I fell off lol
I've decided to 'pull my finger out' and I ordered some 21700s from nkon......gonna have a go at 'spot welding' them together with a cheap kit from chi-na and a 12v battery, might end in disaster but errr, he who tries lol
my TSDZ2 is on a really old Decathlon Riverside which I bought for next to nothing off an old gentleman who had ridden it twice....
I'm lucky here as lots and lots of backroads which are very quiet and even when I go a little 'off road' the going is not too bad....
Just recently I was trying out some Trans Euro Trail and it's clear I need something with suspension to 'explore that little bit further'
I love the look of yer light colored Boardman on left above, cracking job that, congrats!!!!! AND the other one, I think I had that bike myself once upon a time, but just something else the ex 'stole off me'.....
Happy riding sir!!!
frenchie, I have ridden bikes for over 60 years, from the old bone shakers with rod brakes up to the modern MTBs and now E-MTBs built on Boardman, Giant or Specialized frames, Boardman current favorite as NOS frames cheap on Ebay, the grey 29er have Rockshox 35 forks to put on it at some point, ride every day and pick up shopping etc, so get exercise with a bit of weight training. Anyway prefer Tongsheng drives, more natural.
So... You want a suspended 29er to do pensioner city bike duty. The bike equivalent of a mall crawler jeep. Okay. The heart wants what it wants, I guess.
I advise against Tongsheng products because they don't do their homework before taking your money.
The TSDZ2 & TSD2Bs I have suit me, covered over 6500 mile between them, use them for city shopping, track and forest riding so far with out any problems, had the Bafangs both in hub and middrives, prefer the torque sensing system of the Tongsheng.
