Dashboard compatibility help needed
mekaniku
10 µW
România
Hello
I am in need of help to find a good dash, i have an HWWH S3ZB first gen E Scooter
That comes with 2x 60V 3Kw motors + 60V40Ah battery
Current dashboard i use is a generic QS-S4 dashboard that is connected to the master controller (the slave one only has the turn on signal and throothle wires, no data to it)
And as i saw on the second gen one (S3ZB-2),it comes with a different dashboard but same controllers
What dashboards can i install on it? I need something that supports thumb throothle
The master controller is
FOC CONTROLLER A
ASH126045ZPX
As far as we've seen so far, controllers using that specific type of integrated-throttle-trigger display unit don't have a separate throttle input, they get their input digitally from the display itself.
So to use a different throttle with that kind of system, you'd need to open the display, and connect your new throttle in parallel with the existing hall sensor inside the display. There are some pictures in the vairious threads about this kind of unit, sometimes call hte TF100 or TF-100. You may also need to disconnect the 5v lead from the existing hall sensor to avoid interference and/or remove it's load from the tiny powersupply in the display.
Its not a problem about the throttle, but i want a dashboard that is different than LH/QS/TF
I can confirm that with my controllers S886, TF-200 and G51 Dashes work, Now i use the S886 because the throttle is in a better position..
