ebikebuilder
🔌 New-ish
Thank you very much for your answers. I see how it's done now. I'm embarrassed by my lack of knowledge.
So, does this mean I should first flash the file OSF_TSDZ8_VLCD5_KATANA_V00_01_33.hex, and then flash the TSDZ8_config.hex file over it?
I have updated the display firmware again with the file EKD01_UART_TSE_N22_bin. However, it is still not working. The main screen shows error code E02, but when I check the error list in the menu, errors E00 through E04 are all displayed.
What should I do now? Please help.
Thank you.
yes that is correct to my understanding, V00_01_33 is the latest OSF hex file in the git hub
i havent updated the firmware on my EKD01 display , i think that is only necessary for the 860C or the SW102 which have more functionality
error 02 seems to happen when you start the display / turn it ON, and your foot is applying pressure on the torque sensor
although, i had an error 02 earlier today where even when my foot was removed from the cranks i couldnt fix the error 02, i pedaled really hard on the cranks and turned it on and off aagain and the error 02 went away.
I made a video here where I originally set up the tsdz8 osf with the mstrens/OSF firmware (using an ekd01)
I show the somewhat confusing process of calibrating the torque sensor, you might be getting the error 02 if your torque sensor isnt calibrated, Id try like 215 or 220 for the ADC no weight , and 450 or 460 for adc max weight (i measured up to 479 on mine) , I had to set Adc step to 12 to get the torque sensor to feel like it was doing something.
Im still messing around with it myself and Kind of scratching my head as to why the factory firmware felt much more powerful despite using the same power levels and battery current
