Yamaha hacking dongle to use 3rd party batteries
Got my chip today after 3 weeks to US address. Got it soldered up to a hailong 36v 11Ah pack and running perfect. Very nice product. :)
Hi Is it possible to show us some photos of your achievement? I have a Haibike All Trail 3 with Yamaha PW-S2 E engine I think about installing a small battery for short hikes.
Thx
Would this work for a yamaha wabash rt bike built for the US market? Thanks!
Hi I've had the dongle for awhile now and just picked up another haibike ,but when I use the dongle it's great,switch bike off and it doesn't connect when I switch the bike on, I have to disconnect the dongle from battery and bike ,then reconnect to battery then bike to get it to work, any ideas why?
Hi, I cannot answer your question but I would be interested to see the image of your montage on your haibike mountain bike because I am interested in a future montage on my all trail 3. Thank
Perfect,
i have already used 2 of these, made by a forum members in the german pedelec forum.I hope yours are working with yamaha 2016, 2017 models as well?
What about the Giant?
Greets
Sava
Any sign of doing this with bosch batterys are only 36volt and on a 29sl haibike theres tons of room for another battery the old 2014 haibike hardtail with a bosch motor and bosch 500powerpack.
Yamaha PW series mid-drive motor hacking dongle to use 3rd party batteries
Please post your questions about the Yamaha dongle here.
See the full article: Yamaha mid-drive motor dongle to use 3rd party batteries
As with other brands, the Yamaha PW series motor doesn't allow to use any 3e party battery. But with the use of the dongle described here, the Yamaha ebike will be hacked so that you can use any battery instead of the original expensive Yamaha battery.
This are the most important characteristics of the Yamaha battery dongle:
  • You can use any battery on your Yamaha ebike instead of an expensive original Yamaha battery.
  • The battery capacity is measured very accurately with an LTC2944 fuel gauge IC, not just simple voltage measuring.
  • The battery capacity is stored in an EEPROM so that it is not lost when switched off.
Hi
I installed the dongle in a yamaha bicycle one month ago, It mostly works fine but I somentimes have a problem. I got the error 72 in the display and a blinking empty battery. Could it be because I have charged the battery without turning on the display? I think the connections are finely soldered and I done think it has nothing to do with humidity since the bicycle is stored in a dry indoors space.
I tried turning on a off the battery and it sometimes works to reset the error.
Maybe you can guide me with a solution.
thanks
Promising great job... looking forward testing it :D
Is there a plan ta have it adapted to Giant bicyles soon ?
Theres got to be a way around it. If u look at the cable on the syncdrive giant by yamaha coming from the motor end its only got the normal red+black- cable!! Its only from the cable coming from the battery that has them extra cables CAN BUS i think there called but has anyone tried a flash? I dont wana open mine as its in perfect working order and the motor but my display the the control one is turning on all lights on and going straight off for those who know a lil about them if theres a issue with motor battery watever only a certain number of lights will come on and will change colour.im been told faulty display from water i waterproof every component on a ebike to insure no liquids getting in im off to trouble shoot it now ✌️great news on the dongle tho 👊
Hello everyone, I just received the dongle and I'm not sure how to connect it to the motor, do I need to open it and connect all 3 wires?
Адаптер для взлома двигателей среднего привода Yamaha серии PW для использования сторонних аккумуляторов
Пожалуйста, оставляйте свои вопросы о ключе Yamaha здесь.
Полную версию статьи смотрите здесь: Yamaha mid-drive motor dongle to use 3rd party batteries
Как и в случае с другими брендами, мотор серии Yamaha PW не позволяет использовать аккумуляторы сторонних производителей. Но с использованием описанного здесь донгла Yamaha ebike будет взломан так, что вы сможете использовать любой аккумулятор вместо оригинального дорогостоящего аккумулятора Yamaha.
Вот наиболее важные характеристики аккумуляторного ключа Yamaha:
  • Вы можете использовать любую батарею на своем электровелосипеде Yamaha вместо дорогой оригинальной батареи Yamaha.
  • Емкость аккумулятора измеряется очень точно с помощью микросхемы датчика уровня топлива LTC2944, а не просто путем измерения напряжения.
  • Емкость аккумулятора хранится в EEPROM, поэтому она не теряется при выключении.
Хорошая работа. Как купить этот ключ для Yamaha серии PW 2016?
Hi Avandalen
Your Yamaha dongle works great.
I just bought a 2017 Haibike Xduro Race S 6.0 that has Bosch motor
Do you have a dongle that works with this Bosch motor?
Does anyone have experience with bms boards for ebike battery?
Sure. There are thousands of threads about that around here.
But if you want specific info, you'll have to ask specific questions, in reference to specific boards and batteries, because there are *at least* hundreds of thousands different BMSes and batteries out there. ;)
Hi, I have also just bought the dongle. What I discovered in my Haibike full7 battery conector is that there seems to be 2 data lines.
So what I have is three thick wires: red (+), black (-), yellow (I think for charging)
and two thin wires blue and green.
How do I connect those thin ones?
Could it be that my version of Yamaha-battery (X1R-00) and Motor PW-ST has a CAN-bus and that the dongle will not work?
If yes, I have sponsored your work with pleasure. Do you know a solution for CAN-bus?
I would appreciate an answer, thank you in advance!
hello all. new member here. Got a Yamaha Wabash RT at a pawn shop, no keys, no charger, but has the battery. The display powers on but then shuts down about 2 sec later. I did some google searches and found out about the
Yamaha mid-drive motor dongle​
which led me here. I would like to know if the dongle should work with my bike so I can use 3rd party batteries. Thanks.
Hi I have received your dongle about a year ago. My 500wh 36v Yamaha external battery is still working, so I have not yet installed the dongle, or bought a new battery. I would like something equivalent to 750WH which I can mount in the same space as original battery. I'm open to other voltages if there is advantage. I'm in USA. It's a Haibike Sduro all mtn 2020ish PWX motor. Thanks for any suggestions. :)
