grand-moff-tarken
🔌 New-ish
Thanks amberwolf
Yeah, it had not occurred to me until yesterday that maybe the cells themselves are not exactly what they seem (or were advertised to be). I have continued my charge/discharge experiments, and the highest capacity I've hit so far is 1251 mAh....a far cry from the advertised 4800 mAh. I just ordered the correct temperature sensor, so I'll be able to monitor the actual temperature as opposed to just feeling the outside casing with my hand. Ultimately, if the performance continues to be this low, I'll just return them and buy something else (maybe LiON packs, if not too expensive).
FYI - I am not shutting down the charge myself when it reaches a particular target voltage. Rather I am letting the Tenergy unit shut the charge cycle down when it senses the voltage drop (that's what the "NiMH sensitivity" mV number is all about). The unit has four safety features you can enable to avoid overcharging or overheating: mV drop sensitivity, total capacity delivered, overall time and the temperature probe (you can choose which ones to turn on or off). Right now, I am using three of them (everything except the temp probe), and I presume it is the mV drop that's shutting the charge cycle down (it never even gets close on the overall time or capacity settings). I will take your advise, however, and try some "temperature-only" charge cycles once I get the temp probe.
I must say it's been very interesting using the Tenergy unit, if only to monitor the mAh quantity either absorbed or discharged on each cycle. If you don't have an instrument like that available, I guess you'll never really know how close to the advertised capacity your batteries are getting!
Thanks very much again for your time and advice. I will continue to post any new findings or updates here
