Ugh damn Chinese controllers
ctbrisboy05
New here
connecticut
So i have a 5 wire throttle with key lock. Red green black for the throttle. Yellow and white for the key. The controller I have does have a specific set of wires for the key switch which is yellow and black. So Im wondering what do i wire the key switch to? See my pictures. Thanks everyone
Can you post pics of the throttle connector(s) and the key switch connector from the controller?
Where is this connector?
“The controller I have does have a specific set of wires for the key switch which is yellow and black.”
Posting in case you don't find it:
If those are all the connectors, I would guess that this controller does not actually support internal on/off switching; normally there would be an "ignition/ignite/e-lock/etc." wire. If it doesn't, that means you can't use the key switch to power it on/off without a separate antispark/contactor. Alternatively, if you just want to use the key switch as a lock, the easiest way would be to hook it up to the brake connector-except that the switch might operate it in the reverse direction, making it only run when the key was out... Possibly the alarm connector would also work if you could figure it out, but unlikely and difficult.
Is this the same controller ("brainpower") as in your other thread? Because I found this in your manual image: 1768696246635.png
Power lock is what you want.
There isnt a yellow and black on the controller. Look at previous pictures
Ok, I assumed it did because you said so.
The controller I have does have a specific set of wires for the key switch which is yellow and black“
I found it.
As it says in your manual, the thin red wire is the switch on/off wire. You have it hooked to the main power so the controller will be ON all the time.
Does it go to the yellow or white wire on the throttle?
If your throttle only has a key switch, then it wouldn’t matter. One wire from the throttle key switch would go to battery +, and the other to the controller’s thin red Electric Key Lock/Key Switch/Electric Door Lock/Ignition/Power Lock/Controller Power wire.
if your throttle has a battery level meter, then you’d want to do some testing before connecting them.
Ok so I hooked up the red wire from the “alarm” wire to the white wire on the throttle and it gave power to my switch when it was connected. The battery gauge showed up. However when I turned the key off the motor would still run. So i think the other “alarm power supply” wires are the ones I need to wire to the white and Yellow. Those are red and black. I guess trial and error at this point and hope not to fry the controller
Why are you messing around with the alarm wires??? What battery gauge?
