I considered that but it's as tight as new. So I might be able to replace the fork? I did notice that the blades are rather rough, not smooth, and seem destined to destroy the forks. What materials should I look for in a fork or fork-and-blade set and where might I find them/who uses them outside of bikes? Searches don't turn up matches that resemble bike battery connections. Is this one side of a fork?That yours appear to be losing connectivity over bumps makes me think the battery is loose in the base.
The blades are rough and eroded from several disconnections/connections while under load, possibly exacerbated from poor alignment, poor materials, poor spring tension, or incorrect sizing.I did notice that the blades are rather rough, not smooth, and seem destined to destroy the forks.
Thanks. 48V 15aH with intent to add a second similar battery and a balancer if it affects your design decisions. The frame housing the battery makes it tricky to configure something I can disconnect by hand as it's all enclosed. Here's the inside/back of the connector.If you say what volts and amps you are working with we can make recommendations.
Amp-hours are not the same as battery discharge amps and do not have a direct relation to power connectors. The same connectors do not work the same for 25, 50, 100 amps. So I will be more specific and ask what is the peak battery amp load for your controller?Thanks. 48V 15aH
The controller is a Phaserunner V6, 90A Peak Phase Currents (~45A Continuous) purchased separately from the factory battery. And this is the factory controller's numbers if that helps.what is the peak battery amp load for your controller?
I grasp the connecting but can't see how I'd be able to unplug it as the base is not accessible once in the tube. I'd need to fish it through the bottom which is stuffed with controller and wires then cap it with screws each time I take it out which is like doing maintenance twice a day. Is there a way to align plugs or upgrade the fork-and-plug so that the battery can drop in? Otherwise it seems this solution might only work if I put my internals outside the frame so as to access them, which I'd rather not as this is my all weather off roader.You need a drill, some grommets ( auto parts store may have them? ), a soldering iron, two antispark 90amp connectors
No, more like this:Searches don't turn up matches that resemble bike battery connections. Is this one side of a fork?![]()
That's going to depend on the space and configuration constraints and your ingenuity and skills.Is there a way to align plugs or upgrade the fork-and-plug so that the battery can drop in?
Obviously here I had the luxury of not having to use the original base, so no space constraints there, freeing up plenty of space to arrange the pigtail for accessibility and water resistance. Maybe you can do similar? Do you absolutely need the base?
I do need the base to hold the battery in place. I really haven't had much movement from the battery at all. The grating has likely occurred because the round design does not perfectly align with the pins' rotation when dropped it. I think replacing what AliEx calls this "Power Discharge Connector" bi-annually is my best bet given the option of wearing my guts on the outside. Though I'd still like to find the best I can materially. Metals to look for in components would be appreciated.I would run the wires for the battery connection outside of the frame and battery holder. The holes that the wires go out of should oriented downwards so that water doesn't drip into it. use grommets for extra protection against the elements.
You may, after a long hunt, be able to find this part on aliexpress, but the next set of connectors will fail the same way.
Poor design. Like plugging the TV into the wall and using the plug to hold TV to wall. MUST use second fastening devise to hold battery in hole. Bungee cord? Lots of fastening hardware ideas here:I do need the base to hold the battery in place.
Enough connectors to make you crazy at these places.Though I'd still like to find the best I can materially.
To explain what I am thinking. Imagine a electrician stuffing a bunch of wire into a electrical box.Is there any extra room at top of battery tube? If yes? Would a longer flexible wire and ("two antispark 90amp connectors" as Nep says.) Wire would squish into a horrible ball of spaghetti at bottom of battery tube. Use extreme care so that wire never gets pinched. If wire gets pinched FIRE could be the result. BATTERY MUST NOT BOUNCE AROUND EVER NEVER.
Think I am getting senile? What do you call flexible wire with lots of strands? Something you would use for test leads on a multi-meter. That is how I imagine the horrible ball of spaghetti wire at bottom of battery tube. Red and black wires wrapped together in a flexible rubber jacket. Use heat-shrink tubing near connections.
People see lipstick in my toolbox and they think I am weird. Well I am weird.Lipstick
Yes (within reason). BTW, that bottom example is similar but not what came on my battery (MIL-SPEC). That battery was originally from an early generation sharebike. It was designed to slide down into an oversized seat tube, mating with the male connector housed down near the BB. I removed the connector to use it in a more horizontal "permanently" mounted orientation, with the wires brought out of the battery case to connect manually to the controller.Can I use any config of 4 pins or the bottom example as (i think) @99t4 used?
Up to you. Looks like your battery wires simply consist of + and - which makes it easier.do pin numbers not apply to some? Can I just remove two or only connect four?
