IncredibleEddie
Hey all — working through an ebike upgrade for my dad's bike and want a sanity check before I start.
The bike: FreeSky Swift Horse Ultra X-6E, stock 48V/30A controller (label shows it's made by a company called LSDZS — generic, not Bafang or KT branded), stock display is a King Meter unit, speed sensor (not torque).
The problem: PAS levels are way too spread out for what I want. Roughly PAS 1 = 10 mph, PAS 2 = ~18 mph, PAS 3 = ~20 mph. I've got it capped at 20 mph to keep it Class 2 legal, but there's no usable step between "slow" and "basically at the limit." The stock controller is locked down — no way to adjust the PAS curve or per-level current/speed.
The plan: Replace the stock controller and King Meter display with a KT Kunteng 36V/48V 25A sine wave controller kit (comes with LCD8H display, brake levers, thumb throttle, and PAS sensor), everything plug-and-play with matching connectors. The motor connector on the bike appears to be an 11-pin Julet-style plug, and the KT kit I'm looking at comes with a matching JL-F-L1121 female plug built in — so hoping that's a direct connection with no adapter needed.
What I'm trying to figure out:
Appreciate any input — trying to get this dialed in so it rides more like a bike and less like a moped, while staying reasonable/legal on top speed.
- Is the King Meter → KT display swap really this straightforward, or is there some quirk with FreeSky/King Meter systems I should know about?
- Anyone dealt with the 11-pin L1121 connector specifically — is it actually just 3 phase wires + hall/temp signal wires under the hood, or is there a gotcha with pin mapping between brands?
- For PAS tuning — is the KT LCD8H display enough to set per-level current/speed limits, or do I need the USB programming cable + software to get real control over the curve?
- Anything about cadence sensor magnet count I should double check before assuming the kit's included PAS sensor will just plug in and work?
- Is there anything else I'm not seeing here — any reason this isn't as simple as a plug-and-play controller/display/PAS swap?
