DosCom32
🔋 Established
In the end, I decided not to remove that tire from the rim myself. I only cut through one of the beads with the Dremel, then decided to leave the rest to the shop. I'm pretty sure I could have cut the whole tire off if I wanted to, but I figured it was better to let them handle it.How did you get old tire off rim?
I asked the technician if he could please clean out the Slime because I'm going to use FlatOut, and he actually looked annoyed. Can you believe it? I even put a sticky note with that instruction directly on the tire just in case.
At this point, I'll just wait until I can get another sacrificial rim and practice on that one instead.
